Technical resisters
Technical resisters
easyrider
The interior fan blower has stopped working so I suspect the resistors but dont now where to look for them so could somebody tell me where I can find them. Thanks.:)
If the resistor pack is gone then the blower usually still works on max, the resisitors just reduce the power for the other settings. Does yours still work on max? If not then look elsewhere for the fault, like fuse, switch or the fan itself
The resistor pack is right next to the heater fan motor
Thanks for the reply.:) No it doesn't work on max,so i'll have to look somewhere else seeing that it can't be the resistor pack. :idea: Before it stopped working all together it was intermitetnly stopping and then after a minute or so would start again.:confused:
problem solved! it was a bad connection near the blower, I played with a black oblong connector thing and the blower suddenly stated working again on all 4 speeds. Conclusion bad neutral junction connector because the outside air temp display had also stopped working and now works.
