It is a while since fitting this and my memory is a bit foggy. I need to check the clearance around the resilient spacer as it seems to be rubbing in two locations judging by some scoring marks. I cannot recall if the removal of this means that the wheel bearing crushable spacer setup is affected. That was a bugger to set up and I don’t want to upset it again. Any comments appreciated.
