a 1994 1.4 tipo DGT well looked after but has seen a lot of wintertime commuting, thats my guess. only welding it has had is to the LH rear wheelarch forward baffle plate, failing mot at the time because seatbelt anchor a little way above that area. there may be more that would attract the attention of a welding-work seeking mot testing station, if you get my meaning, but its a pretty sound car overall. its been stored in the dry for the last 2 years while i get round to tidying it up to go back on the road. there is a problem though with the rear subframe mountings, caused by all the salt its seen perhaps, that isnt gonna be easy to fix im sure. the rear subframe front mountings seem fine but the rear pair are falling apart now that the thin steel that surrounds the rubber is rusting through. as i understand it you cant get replacement mountings (not normally anyway), only the subframe with the mountings fitted in the factory, nice.. so, i am here now in the hope that there are owners using this tipo forum who can explain how these mountings just maybe can be replaced in some way shape or form so i can get the erstwhile silver machine through another mot. i will find a way i am sure, after all the investment of 67.00gbp when bought on ebay 5 years ago must be recouped! its been on the road for less than 2 years in total during that time and is too good to scrap. i guess i have to regard it as a classic with it being 19 years old now, so if thats the case common sense doesnt have to apply.. also the more tipos that get scrapped the more reason to preserve this one. mileage just over 100,000, has good/nice brakes although steel pipes needed replacing when i first got it. engine very lively and smooth once i found the bad connection to the inlet manifold temp sensor. ill shut up now and hope for some replies before too long, fingers crossed
