improveddc
- Joined
- Jan 27, 2007
- Messages
- 30
- Points
- 13
Can anyone provide a guide to changing Coil pack on Mk2 16v Punto? Is it a simple remove and replace process or does it need to be in some way installed in sync with th engine?
anyone tried and had problems, i am no mechanic but have basic tools and if its straightforward should be able to do it. Or should it be a definate garage job?
thanks
P.S. i notice the whole guide to checking ECU/Coil Packs on here seems to relate to the 8v engine i.e. with 2 seperate coils. HOw can you check if it s a coil of ECU problem on 16V version where coils are in one pack?
thanks
