Technical Replacing all of the punto 5 speed gearbox bearings
Helsinki
Easy box to repair. You don't even need box out.
Remove selector from top of box then move selector forks to select two gears, loosen or tighten large nuts as required.
Thanks, I am not sure what you mean by moving the forks to select two gears?
You also say you do not need to take the box out, I am supposing you mean you can leave the bell housing on the engine and replace the 6 bearings with the rest of the box out of the car?
