Technical  Replace front fridge with 3rd seat
silverfoxdiver
Hi
Does anyone have any info please on whether it is possible to replace the fridge between the front 2 seats with s 3rd seat which seems to be the common setup on most Multiplas?
Hi there. it will fit easy enough.remove rear seats, remove front seats remove fridge. fit new centre front set,make sure you fit the bolt on the left centre hole,this allows the seat belt pre tentioner to work.also when refitting front seats ,make sure you move them outwards by about 1",holes already in floor and threaded,so you can use the centre seat belt with out it jamming. dont turn the ignition on when front seats are out as you disconect the air bags under the seat ,and turning the ignition will make your air bag light come on. deep cranked spanners make the job easyier....mp
Last week I needed to pick up a motorbike from Yorkshire (Aprilia 650), so I took out all of the seats except the drivers seat, easy job and a massive space created, the bike went in no bother and lay on it's side on some old settee cushions. The airbag light was on all the time while the seats were out, but so what. By the way , great bike with more torque than Terry Wogan !:slayer:I greased all of the seat bolts to make it a bit easier next time.
