Technical Removing footrest
get
Zagreb
Does anyone know how to unscrew footrest screws?
Because, I have unscrewed one and I can't back the screw back.
Footrest, what footrest?
Says the owner of a RHD Bravo. ;)
The one Get might shove where the sun don't shine................
eLearn - Contents
198002294.image
20.image
Removing ( Refitting ) 1. Undo the bolt.
2. Remove the footrest (2a) releasing the inner retainer (2b).
21.image
Refitting ( Removing ) - Check that the footrest is not damaged.
- Position the footrest and attach the inner retainer.
- Tighten the bolt.
Thanks for that.
But, that's for "regular" footrest (not for sport footrest).
As you can see on the picture, I have three screws.
I don't know how to screw it back.
What did you do, son of Brutus:))
How did you unscrew it? and what's the problem now?
I want to change original screws with new stainless steel screws. But the problem is that you have no chance to screw old screws back. So I have to use bigger screws, So, I wonder how are they originally tightened.
I don't know. I have to remove other two screws.
If you try put the first screw back, does it go loosely in, or does it not go in at all?
If the former, it may be there was a loose nut which you have now lost :cry::cry::cry:
If its the latter, then you may have a tuft of carpet or something blocking the thread on a captive nut. The solution to this might be to take the other two screws out. However, if its the loose nut problem, then it will only make matters worse, and it will likely be a "carpet (partially)out" job.
Thats what I thought, if he can't see the thread, there must be a nut there before but now dropped to the floor. nut insert time me think~~~:devil:
It makes sense.
But it's so stupid to put unfixed nut, isn't it?
Is it big problem to remove carpet out?
I made my own especially as I wear size 13+ shoes.
Mine is a RHD automatic.
You can see the plate the footrest attaches to in one of the pictures. The OE one that is part of the trim is just hopeless so it is totally correct when it is said the trim has to come off - but forever!:D
