volvo_saint
I have a FIAT SEDICI which requires a forced re-generation every 600-800 miles.
As this put the car off the road for 2-3days and costs on average 60 pounds to fix this is rather a downside.
Further more the oil level keeps rising and I suspect that Diesel Fuel has found its way into the sump. I have not added any oil to the engine since I have owned the car.
Apart from entering a legal challenge with the dealer about the DPF unit my other solution would be to remove the DPF unit and 'dummy' the sensors into thinking that the unit is still there.
I examined the DPF unit and it has the following numbers stamped on it - 55204393 and 01922.33. Its made in Germany and there is a sensor plugged into the DPF unit.
Recommendations so far is to remove the DPF unit and remove the internal filter and put back a hollow DPF unit.
Does anyone have any technical information on the DPF unit?
