Technical removable sunshades on ebay...
ashy_2002
ashy
lancs
Well they arrived yesterday...
They come very well packaged... (Logo’ed bag) its seems as though they are an actual fiat part??
There's six panels (very sturdy) they fit like a glove its about a 60% tint ... the panels are fitted with small high quality clips that use a gel sticky adhesive I’ve never seen this type before but sticks like a teenager on Pamela Anderson . Good instructions for fitting... but I would suggest when fitting to attach the clips (without taking the film off) to the panels get the best position and mark with a thin tip permanent marker , therefore the position + tension is correct... . when fitting the clips make sure that you use a large flat screwdriver to push the clips against the surface and create the strong gel adv bond
The panels are easily removed when required... the panels at most angles produce an effect that you can't see in the van... my girls are very happy with the blacked out look... but you still can see out very well... was coming home tonight up the M1 (it was hell) , towing a caravan chassis and didnt have to dip the internal mirror
The passenger panels are cut so you can still open the sliding window.... therefore you can have the window open with the sun blind intact + acts as a bug repellant... same for the rear openers....
I'll take some pictures after I've washed the van!!! + cleaned the inside windows properly... :rolleyes:
They only cost £99.00 with £11 delivery... which is far less than tinting which I was quoted £280 for six blacked out windows. if you go to b+q etc... put lots of stuff in and it scratches a tint film then its ruined ,, with these you just remove / install when you need to... who wants overhot kids balling in the back of a seven seater family ?
A thought ..... if you got a spare set of clips or removed the clips (you'll need new adhesive) and reinstalled in your NEW doblo then more savings.... I don’t like paying over the odds for anything...(y)
I realize that over time the panels may "grey" in the sun ... I think that’s the only down side... but they will still work.. (Unless you remove them and only use when required)...
They sound good!
I was quoted £180 for all the windows except windscreen and front side windows, with a full lifetime warranty as long as I own the car, if it gets scratched, peels or anything they replace it free of charge :)
have you any pics of your doblo with the sunblinds fitted, i saw them on ebay myself and thought it was areally good idea. i am new to the doblo range so is there anything i should look out for please,julie
To follow.... very shortly... I've just sent pictures to the company who supplied them at their request... I just got to remember how to attach the pictures to this forum....
Heres some pictures
HOw do they attach again, not to the actual window like that tint film that you have to stick on the actual window, bugger to get off, on clips, i dont understand. If they are away alittle bit from the window surely they still let sunlight in around the edges, sorry for being stupid, please help me cos i am on the buy now button on ebay. Ordered my blue doblo now, i pick it up Thursday
They attach by clips set of four per panel ... They are mader to measure that is they are shaped around the window openers etc... they are easy to fit + take out ... but take some time fitting them to get the best fit... ... no they don't leak sunlight at the edges....
Ashy,
We are interested in these shades, mainly for the benefit of our dogs. However, we have the split rear doors on the Dobbin. I have e-mailed the sellers, but they can only say that the rear screen is 'split'. Do you think that they would fit the 1/3 - 2./3 windows on ours?
Ashy,
The rear set comes in two equal parts which fit across the rear "hatch" 1 door type.. personally I don't think you could fit these to the rear doors of your design.. given that you could still install the side panels no problem.
If you have large dogs which are not caged + prone to jumps up at the windows then this product is not for you... but I would think you've already thought of that... :eek:
Before reading the last two replies i have purchased the sun shades of ebay not realising that the model i have got is the sx with side hinged doors rather than the tail lift door at the rear of the doblo. The company did ring me after buying the shades and asked me to try them and if they were no good i could send them back with no problem of a refund. Fair do,s to them. They should arrive tomoz and i will see and take pictures of them for this forum and their web page and then they will update their model range that it will fit to active and dynamic models only.
Just be aware that these sunshades will not fit the 6 door models, only the active and dynamic models. They will not fit the rear split doors on amy of the models any age. The side one fit perfectly. Will have to send mine back. Picked up my Doblo today its great
I have fitted the blinds on the sides as i contacted the company who supplied me and in the end rather than send them back they offered me a part refund that i was happy with. These blinds are the business and dont i want to put any one off them for the 5 door models, they were made to measure and are a lot different to having that film fitted , which always looks awful in time. These can just be clipped off when you dont need them, like in Winter. They come in a Fiat logo bag with a zip on and you can just store them in the boot when you dont want them up at the windows.
great quality!
i got a set of these for 80 quid from same place in derby great fit, i have had my dobbie tinted and have these on inside as well so nobody can see in but i can see out perfectly even at night :)
Heres some pictures
Saw your pictures on the sellers Ebay listing. They are down to £69 + postage now! Ordered some, they should be here soon. Like julielew I have the side hinged doors so if anyone wants to buy the rear panel, I'm open to offers!
