Hi, I just I wondered if anyone had come across this particular problem on any recent Fiat or indeed even any car. My key fob, say about 50% of the time, refuses to lock the car. This behaviour just suddenly started about a couple of weeks ago.
Before you ask, I have now changed the battery in the remote twice, making no difference. The key fob will unlock the car without any problems 100% of the time but intermittently will not lock the car leaving me pressing the button over and over. Sometimes I give up & just use the drivers door lock switch or else sometimes it starts working again after the umpteenth go and works fine for that period, even a long distance away from the car. It seems totally random but more often than not it won't work when I leave the car and I can't figure out what changes when it suddenly starts working again. I am thinking some malfunction within the remote, dry joint? capacitor?, but the randomness throws me a bit. I wonder if the receiver in the car is just not recognising it somehow, a software thing... I think I'm going to have to bite the bullet and approach a dealership, as not even some kind of clue has surfaced, but I know a replacement remote can be up to £300, so you can understand my slight reluctance.... I can't even think of a way to test the remote (some manufacturers provide two)
The only other thing that has happened but I'm assuming is completely unrelated, is that the main car battery went kaput, (a long way from home...would no longer take any significant charge) last weekend, leaving me stranded. I made it home thanks to a boost start from Green Flag... (Driving batteryless threw up plenty of odd behaviours and fault messages on the meters!) ...and then I replaced the 12v battery (Eurocarparts Lion 027, very similar Ah and CCA as the original)... and all else seems well & normal again but this particular fault was there before and after with no change...
P S, when I took the original battery out to have a go at bench charging it for a short while, it occurred to me that with the doors now locked and the car not having any electrical power, DON'T SHUT THE BONNET! As how do you get into the car to open the bonnet again and refit the electrical power source... My neighbour reckons that if this happens there is a little manual trick switch lock somewhere on a normally hidden part of the door handle but I don't know....
