Technical  Remote Central Locking
djrpowell
this is my first post here but second Marea!!!
I have just got a V reg Marea 1.6 Weekennd 28k on the clock for £2150 not a bad price, the car is in a good state!
However, i need to upgrade the central locking which already does all doors and boot to a remote central locking version.
I have seen lots of Ebay options etc.. but can anyone tell me how it works on a Marea.
Does the Marea have a control centre or somthing in the drivers door for the alarm or remote module to plug into.
I only want to spend £30-40 quid for a cheap one!
Daniel
i bought this off ebay
http://cgi.ebay.co.uk/Remote-Centra...010199222QQcategoryZ15329QQrdZ1QQcmdZViewItem
fairly easy to fit, very good range and a good quality fob and button, easy to fit.
All you really need to do is take a permant live from the fuse box behind steering wheel and trace the two wires from the drivers door. 1 is white and the other is blue. These are the open and close and can be found under the plastic kit plate on the drivers side (cant remember if white is open and blue is closed, if you get it wrong just swap over 50-50 chance of getting it right).
then run the two indicator wires to the hazard switch so that the indicators flash.
Some of the electric bods on here may have another way, buts how i have done it on my last 2 mareas
cheers
smtvlive
Thanks,
that sounds cool, i will give it a try and get back to you!
:worship: :worship: :worship: :worship:
I have found a really good system from META;
Meta HPA 2 Remote CDL
http://abacuscaralarms.co.uk/store/view_product.php?product=Meta HPA 2
FEATURES:
Two 2 button remotes using 128 bit antiscan antigrab technology
Status output LED
Full central locking output control
Total closure output (if fitted by manufacturer)
Flashes indicators
Positive output for other modules (such as window/sunroof closures)
Built in Immobiliser
Output for horn or siren (not supplied)
This unit is sold as a remote control add on to existing central locking in vehicles. It does NOT come with a siren and Ultrasonic sensors, or the capability of directly controling these sensors.
Technical support is not available for the alarm features of the HPA2
Fitting Instructions (HPA2)
Full Programming Instructions (HPA RANGE)
Not sure if your vehicle is compatible then CLICK HERE
