Relay Ticking Like A Bomb! Help!
M
Markpro
One of my Relays is driving me mad, It's in the box at the back of the engine bay under the windscreen, i think it's the realy on the right hand side, what happens is ( not always but most of the time ) when idling it ticks like hell
ticktickticktickticktick, but when i depress the clutch it goes tick....tick....tick....tick....
when i lift off the clutch it geos crazy again ticking like hell, I think i read somewhere that it's the ignition Relay but i'm not sure, anyway is this normal or not, Iv'e never had anyproblem starting the car just don't want it to get any worse.it happens when driving as well but it's not as noticeable because of the engine noise.
anyone help?
If you can take a photo, i can check the haynes manual for you.
What model do you have.
Daz
Re: Re: Relay Ticking Like A Bomb! Help!
Cheers Daz but I'm sitting here with the Haynes manual in front of me and i can't see where it says what relay it actually is, page 12*4 mentions a little bit about Relays but nothing helpful, there is only 2 Relays in the box but i'm positive it's the one on the right hand side, just need to know what it's for and if it's going to be bad news
Re: Re: Re: Relay Ticking Like A Bomb! Help!
Oops sorry just read the rest of the post
It's a 1.4 Brava 98 reg
Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
are you SURE its not the clutch?
Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Nope it's the relay, i had the bonnet up and had someone pressing the clutch up and down and the ticking was coming from the relay, took it out and put another one in and it was doing the same thing, it's not causing any problems it's just the noise is driving me up the wall not knowing what it is.even when the car is just sitting there running sometimes i hear nothing for day, then all of a sudden it starts ticking again, any idea's what the relays for?
Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Now that IS twisted!
Not a clue, what stops working when you take it out?
The relays under the black cover behind the battery?
Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
As far as i can tell nothing stops working, Its the right hand relay in the fuse and relay box at the back of the engine bay,
If you have a Haynes manual go to page 1*4 ( Maintenance - Component locations)
underbonnet view of 1.4 litre model it's number 3 on the picture ,fuse and relay box,
I'm just wondering if it's something that i don't have ( electric sunroof or something ).
Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
I'll have a peek later, just recovering from getting in at 8am this morning after a gig.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Cheers for that Tom
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Still no joy, looked at the Haynes manual cover to cover last night, still can't find out what this relay does ( and it's still bloddy ticking )
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
I know what it is!!
Mine was doin it with ignition at 2 (electrics on) it was coming from wiper motor - so i fiddled about with wiper stalk on column and it stopped!
If it aint that, what i just put won't help :)
Hope it is that.
Adam
I know what it is!!
Hope it is that.
Adam
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Man i wish it was that easy but it wouldn't explain how the clutch changes the length of the ticks coming from it, cheers anyway, If i knew what the Relay did i would probably know what the hells is causing it, was the ticking coming from the Relay or the wiper on yours mate?
Ooops - unintended double post.
My tickin was coming from that placky panel at bottom of windscreen.
(as for clutch changeing clicks, - i shudda read ur original post in full).
Adam
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
No probs mate, I think that plastic panel you are talking about is the pollen filter door ( not fitted on all models )can't think what would be ticking in there though.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
I take it no-one has found out what this Relay does then...no...ok.
Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Relay Ticking Like A Bomb! Help!
Not looked, been fixing my sisters Uno and my friends fiesta. I HATE fords.
M
7K
M
3
1K
Tommy K
T
494
Dark Lurker
C
3
746
Tommy K
T
M
796
M
