Technical Relay Map
Technical Relay Map
pgainf
Greetings!
Can anyone please help me with a Relay map/meaning for a Stilo JTD MW 115HP 2003.
I can't find it anywhere.
Every two weeks my JTD won't start until I remove and plug again some of the relays.
If I know which one is the problem and what it does perhaps I can swap it for a new one.
I found out that some of the relays had a bit of green oxidation on them.
I used a metal brush to clean it out, but now it happen again.
There is a good pic of engine bay fuse/relay board in post 4 in the link below,
Also if you have a cover for you battery which is very worthwhile having to stop water damage to the fuse/relay board, there are details of the relays on the underside of the battery cover. a fault code reader is also handy to have and any error codes it may have to find the item at fault.
Being a jtd and having problems starting it may be the relay to the fuel pump,so long as it is not the fuel pump sticking or another item not related, I had problem once with relay for fuel pump T10 in the past and swapped it with the air con compressor relay T5 until I got a new relay,, any ways image in the link below post number 4
https://www.fiatforum.com/stilo/428536-stilo-diesel-pump-relay.html
Been meaning to compile this for years.
