Technical Reduced cabin air flow??
chrisghz
Birmingham
Hi all, i've searched around the forum for similar problems and came to nothing. I have a 2002 1.2 5dr, and I have a problem with the cabin blower air flow. Even when on full hardly any air blows out. this has been the case for a good year...(i know i should have sorted it earlier!!)
Also it makes a buzzing type sound almost like something is in the way.
Could it be as simple as cleaning the pollen filter, or can the intake be easily cleaned??? I've had a look by the bonnet but it looks very complex it dismantle.
thanks guys!!
Chris
thanks guys!!
Chris
Pollen filter blocked... loads of info on that in this Forum. (y)
Take a look at this Guide by Deckchair :- https://www.fiatforum.com/stilo-guides/55320-pollen-filter-how-remove.html
Thanks for the reply! that was just the sortof thing i should of searced for....wrong words.
Thanks again!
Thanks again!
Well that guide by @Deckchair worked a treat a MASSIVE thank-you to you!!
Although the filter is a nightmare to get out its well worth spending a little time every now and again cleaning it or replacing it! I recon I just increased airflow by about 75%! It was full of 8 years of crap and dust!!!
It's a Service item that often gets neglected, bearing in mind the hassle of getting it out it's best to just change it every other Service or so.
