Styling Red Fiat Badges
Very easy job.
Front badge first ,open bonnet then undo the 2 screws/bolts (cant remember which)
that hold the grille front upper section closest to the badge.
With these removed theres just enough room to see and remove the single nut that holds the badge on , replace .
Rear badge next .
Easy way is to warm the badge with hair drier, and carefully slide a thin piece of plastic behind ( old credit card is ideal ) while carefully pulling the badge away, its only stuck with double sided tape.
Clean area before sticking back the new badge.
Wheel cap badges prise off after warming them up the same way as the boot badge . leaving the badge base in place to stick on the new badge.
Clean the base area thoroughly,before sticking new ones back on.
Hope this helps.
Am I the only forum member who finds this badge business a bit strange? (But totally harmless.)
I find it all a bit strange as well. I have the blue badges on a blue 100hp. I don't think the red ones would look as good. Then again they are only badges. But I did put a red scorpion badge on the back and all the red came off, so now it's chrome
