Hello everybody,
I decided to return original Blaupunkt radio into my Punto (2006, MK2b). The problem is that connector for power is reconnected for a Sencor radio and I don't know how to reconnect it back. I decided to see if I can do this by myself before going to auto electrician.
This is schema of Sencor radio:
WIRING PLUG B (CONNECT TO SOCKET B)
- RED: IGNITION SWITCH (B+)
- BLACK: GROUND (B-)
- YELLOW: MEMORY BACK UP(B+)
- BLUE: AUTO ANTENNA
This is the reconnected connector - image 1.
As you can see one wire (red/yellow) from the car is now separated into two wires to the connector and purple/black wire is connected to the black wire.
There are two more wires that are not connected to anything (one wire is pink/white and other one is pink/black) - image 2.
This is the schema of Blaupunkt radio - image 3.
Could someone tell me what I need to reconnect again so the original radio works normal?
Thanks!
Thanks!
