Technical  recommened tyre pressures for long journey
West Midlands
On monday im going on holiday and have a 150 mile journey to do , tomorrow i will be be filling up with fuel and giving the car a good check over .
just wondering what tyre pressures you would recommened.
I'm running sporting alloys with 195/50/15 Toyo proxes T1-R's
(y)(y)
the length of the journey isn't so important,
LOTS of highspeed ( m-way) you would want them on the "fully-laden" figure in the handbook,
unfortunately mine doesn't cover the 15" wheels,
but suspect it'll be @ 34 / 35 psi
wait for confirmation there..!!, ( and have a good trip)
Charlie
On average front are standard 35 and rears 32 (odd number), the other day I pumped mine up to 40 for some long drives with a heavy load and everything was fine
The book states for a 1.2 8v
Standard
Front 29 psi
rear 28 psi
Full load
Front 32psi
Rear 30psi
Obviously there are slight variations depending on the model etc. for example the heavier JTD's run a couple of extra Psi as standard.
Be careful inflating your tires to 40psi! Many small tyres such as those fitted to puntos have a MAX pressure of around 40psi. Bear in mind the pressure will increase as the temperature of the tyre increases. A tyre that is 40psi cold could be 45+ when hot.
The maximum inflation pressure should be stated on the side wall of your tyre. Over inflation can be just as dangerous as under inflation.
Thats a tyre I took of a mk2b earlier.... max pressure 44psi.
Personally I normally stick 31psi in the fronts and 29 in the rears.
Alan
cheers for the advice guys . just another quick question save making another thread, my radio reception seems to be a little ****ty at the moment but the whip piece that screws into the base seems a little loose , can this be tightened , sure i managed to get a plastic cover off before which reveled a screw to tighten ,but i cant seem to now
Depends on tyre size.
(BAR)
13inch. 2.2 front,. 2.2 rear (fully laden')
155/80 r13 79T
165/70 r14 2.2 front 2.2 (fully laden')
185/60 r14 82h 2.4 front 2.3 rear (fully laden')
185/55 r15 81v 2.4 front 2.3 rear (fully laden')
info from fiat book,
For anyone who may come across this thread with other models....
Alan
Hi mate,
As you say, it can be tightened. The cover should un clip IIRc but it can be a bit fiddly to do without damaging it. If you do get it off, give it a good clean with some emery cloth or similar where the swivel point meets the base.
I normally just replace the base when they start getting old and tired.
Alan
Hi mate,
Alan
How exactly does it come apart do you just stick a small screw driver in the end nearest the back of the car in the little hole , And leaver it one way or the other
