OK guys listen up
PNL reporting on the case against fiat by the member and my friend Bombay
I am pleased to announce that fiat have backed down and settled out of court ..this has also resulted in his car being bought back of him from the dealership he purchased if from
Need less to say he is glad this has finally come to a close for him and he can rest on the fact that as fiat backed down they are automatically admitting the fault with the front springs and dampers on the stilo [flood gates should now open ]:chin:
As a consequence of this I can now release the information I was with holding about the fault on the springs ..
This is a direct quote from the chief metallurgist of the institute of spring technology that examined and analysed his broken springs he submitted ..
Quote- The major factor to the breakage of the stilo front springs and the frequency of the brakes are down to the Hardness off the springs 584/593 on the vickers scale which is extreamly high and makes the spring extreamly brittle ..the corrosion is a factor in this but we also examined a spring from a Honda that broke when corroded but this was at 150,000 miles and not the low millage of the fiats we examined ..the hardness and brittle quality was also the contributing factor of the redesigning and withdrawal of the rover 75 spring in 2004 .
So there you now have it his multiwagon is gone
he is no longer a member of the 5dr massive attack and I am sure we will all miss him I know I will as he has shown considerable courage in pursuing this with his dealer and fiat ..good luck Trev good luck for the future and what ever it throws at you ..
Good by Bombay
:slayer: :slayer: :slayer: :slayer: :slayer: The crusader
