having thought about it...
I think the problem is likely to be the self parking mechanism in the wiper motor; this means replacing the motor; you could check to see if it is the stalk or the motor by removing interior panels on door; pulling the connector and use a voltage meter to check what happens at the connector when you operate the switch; you should be ble to get a 2ndhand motor from a scrappie......
