Technical  rear springs help
shotgun
Established member
hi all are the qubo and fiat fiorino rear springs the same
or are the van ones stronger or can you get heavy duty rear springs
ok its just mine is a bit low when I put my tools in
its not bottoming out but just looks low to me
You can get those rubber assisters that go in the spring coils , you may even be able to get assister springs that fit inside the originals to
just fitted 2 rear spring to my qubo from a citroen berlingo / or partner off a 1.6 hdi 2009 on it sits a lot higher you will need the complete spring as photo
they fit ok you just need to trim the plastic top mount a little so it fits in to the qubo mount
the qubo spring is 320mm long & 11.75 thick & 120mm across
the berlingo spring is 380mm long & 12.75 thick & 128 across
X
