Unclipping the filler neck is a muddy mess..and fiddly
Mine were not on properly.. So it was an opportunity for improvement
IF the tank is showing empty.. no real reason the remove the pump.. just uncouple the electrics and lower the tank.
Its just another few KG to support.. pump and 3 litres of fuel
The tank will be well away from the car for welding..
Handbrake cables are in the way too IIRC
Interior trim wasnt an issue.. but might be worth lifting out the under seat 'padding' and unscrew any plastic trim under there
At £60 an hour labour.. you can save a fair bit preparing and reassembling yourself
IDEA: any other local corrosion mentioned?
Could be cost effective to deal with that NOW.. while you are poking around and stripping trim
A word of caution...
My 1st punto 188 was.. a very cheap.. scabby example..
The floor was bad.. I got All of the Advisores welded..as well as the Fails
12 months later..it was WORSE I scrapped it.
This was common corrosion ( factory underseal cracking..then trapping roadspray AND SALT)
If youve had this car for years..you will know the levels you are at
