Surprisingly the 95 1.3 with more torque than the 1.4 petrol and almost as much power still has drum brakes......
The majority of braking on every car is done through the front wheels (80/90% I'm sure), and most cars would get away with front discs/rear drums. The fact is, having discs on the rear looks 'sporty' - that's why the 1.4 sport has them, not for their superior stopping power :yum:
But it does have superior stopping power. I have a 1.4 and i test drove a twinair that had rear drums and was actually lighter than my 1.4, and i immediately felt that the brakes were worse. It took longer to stop in all situations.
That's because the 1.4 has uprated front discs, not because it has discs on the rear.
The price you pay for the bigger front discs is that the turning circle is substantially worse.
Is the poor turning circle on the 1.4 due to the 6 speed gearbox ?
I did do a doubletake when you said that bigger discs = bigger turning circle.That would make more sense.
That cant be. I have a duallogic 5 speed and my turning circle is no better on the 1.4 Perhaps the heavy engine? I cant see how bigger discs = worse turning circle, that would mean that cars with big discs cant turn at all!!! (i am not saying i am right but just a thought)
Raised a good point ahmett. I'm now unsure if it is the actual gearbox that is restricting the 'circle'. Although for consistency they may have all the 1.4s with the same turning circle.
http://carleasingmadesimple.com/bus.../500-hatchback/46372/technical-data/?4810N930
1.4 Manual 10.8 metres
http://carleasingmadesimple.com/bus.../500-hatchback/46366/technical-data/?4810N447
1.2 Manual 9.3 metres
http://carleasingmadesimple.com/bus.../500-hatchback/46373/technical-data/?4810N930
1.4 Dualogic 10.8 metres
Gearbox being a robotised manual of the 6 speed 1.4 has probably lost a cog since it can't use the lighter 5 speed from the 1.2 because of the extra torque from the bigger engine. Only having 5 speeds does not meet the gearbox is smaller.
Although if I check the turning circle on the 1.4 Multi-air in the North America I get 9.32m (30.6ft).![]()
http://blogs.insideline.com/roadtests/2011/06/2012-fiat-500-turning-circle.html
NA 500 uses a 6 speed 'proper' automatic or a 5 speed manual (C514)
http://www.fiat500usa.com/2011/01/fiat-500-complete-vehicle.html
In NA they couldn't use a 6 speed gearbox because it wouldn't fit due to extra crash re-enforcement.
If you compare the European 500 1.4 against the MINI at 10.7 meters it's still market competitive.
[URL="http://www.calculateme.com/Length/Feet/ToMeters.htm"]http://www.calculateme.com/Length/Feet/ToMeters.htm[/URL]
Yes it basically means i get the chance to practice my three point turns quite often as in just before i got home! A short turning circle is handy i must admit!
To the OP, putting discs on the rear is not as scary an exercise as you'd think. Actually, its probably easier than just changing a set of rear discs because you can unbolt the whole carrier.
Buy a rear axle from a breakers with the calipers, hubs, etc. Virtually plug and play. I can send you some detail pictures of the rear assembly on my 1.4 Lounge with discs if you want to see how it fits together.
Please sir!
More pics to follow when I have her up on the hoist this week.
No worries. She's up on the hoist this week getting the coilovers done. I'll snap some better pics and post them up. Essentially there is a welded on vertical tab at each side. The entire assembly bolts to these with 4 bolts that - annoyingly - you have to go through the spring to get access to. Multiple U joint extensions for the socket can come in handy here. Undo them and the whole upright, hub, bearing, brake etc comes off. Straight swap over.
Or as Maxi says, buy a 2010 onwards axle from a 1.4 and you get the whole shebang plus the arb chucked in for free
