marky9074
I ordered from Autodoc a set of disc and pads, luckily with the option to send back within 200 days. For the 1.2 it states the following will fit:
I also ordered the P 24 147 brake pad set which thankfully did fit.
Now, with one front wheel and caliper off I could see the two bolts holding the disc on were tight but not fully engaged (the disc was rattling). I removed them and then tried to tighten them up but didn't get any further in than they were before. I put the wheel back on and then compared with the other side and these were tight to the point I couldn't get them off and feared I would either round them off or they would snap.... There was also not much meat on them to get a socket on either.
So, any tricks of the trade with these retainer bolts?
- 09.8616.11 240mm / 20mm / 41mm ventilated
08.5085.11 240mm / 11mm / 40mm solid (2015 onward so N/A)- 08.5085.11 240mm / 11mm / 40mm solid (With variants 08.5085.75 Max & 08.5085.1X Xtra that are grooved/drilled respectively).
- Model
- 1.2 Lounge
- Year
- 2015
- Mileage
- 70000
