TL100HP
- Joined
- Jan 27, 2017
- Messages
- 42
- Points
- 89
I have a panda mk3 4x4 1.2 51kW, and at the rear I had fitted a classic lift kit consisting of stiffened springs (+3 cm), longer connecting rods, and extended shocks. I found myself in the need to replace the shocks and the garage installed them according to originals specs (Kayaba 348005), the car remained at the same height (obviously), but mostly when unloaded the rear shocks reach the end of the stroke in rebound. Comparing the news to the old ones, the distance between the two eyerings at rest is about 20 mm shorter. Question: is there a shock absorber from some other Fiat model with the same characteristics as ours, but with a greater distance between the eyelets?
