I have to say I'm with you on this Jock. I might remove the hub to make fitting the shoes easier but don't think any advantage would be gained if just doing a cylinder - As you can see in this picture of Becky's rear brake, although I haven't tried it yet, it looks like the cylinder can be removed without having to disturb anything else:
(I suppose also there's always the slight chance of the inner bearing hanging up on the stub axle and getting damaged, although that's probably a small risk) I would be reluctant to risk breaking the back plate retaining screws - which I think are Allen Hex Screws? - I'd rather mechanically attack the wee bolt holding the cylinder even if it had to be destroyed to remove it.
I've read before on here about using a blow torch on the brake pipe tube nut and how it melts the coating on the pipe. I'd rather just cut the pipe off the nut so I can get a socket or 6 point ring key on it and make a new pipe up. (I have great hopes for my new Vibro Sockets on jobs like this). This shot of the back of Becky's back plate shows how it will easily come out with the cylinder if you were to cut the pipe off:
Of course then you've also got to get the tube nut out of the flex hose at the other end. I wouldn't ever put a flame anywhere near a flex hose fitting. New vs old nuts/bolts/setscrews on a job like this? For the negligible expense I'd always just use new ones. As I said above, if you are going to make a new pipe then just cut the old pipe off at the tube nut and forget about undoing the tube nut at all, it'll just come out with the old cylinder. In fact even if you are not replacing the cylinder - maybe just doing the pipe - if you cut off the old pipe and remove the cylinder complete with the tube nut still in it, you can then grip the tube nut in your workshop vice and unscrew the cylinder from it thus saving the cylinder for reuse. I've often found a stubborn tube nut which I can't shift with the cylinder still fitted to the backplate is relatively easily removed in this way. Even at the flex hose end cutting the tube off means you can then get a single hex socket on it which makes removal much easier.
You are correct the cylinder is removable without disturbing anything else, the back of the cylinder looks fairly good and clean, a spray of lube and should be removable without too much trouble, I suggest some lube on the handbrake shoe lever pivot too, it looks like it needs it.
a brake spanner is the best for removing brake pipes, they fit perfect and never round off anything, looks like a ring spanner with a bit missing, I bought mine from the snap-on van 30 years ago and they still look like new, the worst that can happen is the pipe snapping, but I always try to remove without snapping them.
