I think the OP and you are both jumping
to conclusions.
Now let's assume for a minute that both of you are right and the multiair is "bad", whatever that means.
So one hypothesis is it can't pressurize all of the four high-pressure chambers and/or the actuators don't engage and let that (insufficient) pressure provide the hydraulic link which pushes down on the admission valves.
So basically your saying the admission valves don't open at all.
This is normal if the multiair is lacking oil and hasn't been primed.
But it's not normal otherwise.
However, without removing anything, there's an easy way to test this hypothesis.
Just put a condom over the exhaust and crank the engine. If it aspirates, the condom will blow up. If the engine does not aspirate any air because the admission valves never open, it won't.
