Technical Rattle from under front middle seat
Jim Jim
Hello everyone, new to the forum, first thread! Posted it once but I can't find it now so I'll try again.
Multipla 1.9 Diesel. Rattle coming from under the middle seat area. Not connected to pulling away or breaking, just seems to be general rattle from something loose. Had the lower middle gearbox mounting replaced but made no difference. Drop links and shocker bushes already replaced so this is the last rattle (i hope). Guy at the garage had a drive around in it then a look around below but can find nothing.
Another gear box mount maybe?
Thanks.
Jim Jim
Could it be the exhaust heat shield (like thick aluminium foil)? Had this on mine - the shield bent after going through a puddle once. Just bent it back and has been fine for years.
Mark
I did check that Mark, it was bent but no too close to the exhaust, bent it back into shape but the rattle is still there. I put new exhaust rubbers on just in case it was bouncing around too much but I still have the rattle.
