Technical Rain sensor...
Hi 39 & 40,
those options need different things:
- hardware: sensor being installed behind the windscreen
- hardware II: body computer equipped with the corresponding circuit
- software: the BC loaded with the corresponding software (version)
- Alignment: the BC being taught the car got those options (proxy)
If one of the previous is missing, the option won't be available ...
BRs, Bernie
If someone here helped You fix -or better, understand- your issue, hit the thanks icon @ bottom right corner, it's free and makes us feel helpy ;-)
ok, but for automatic light i need of a sensor on Grande Punto? becouse i cant find and i dont know where i put it on car..
Not sure such a feature exists on the Grande Punto...
See description and drawing from eLearn.
BRs, Bernie
hi, can you explane me how to connect the sensor to the bus? ive the widescreen and the elettrocromic mirror with rain sensor, i need to connect the sensor.
Hi Frau, this forum is not just a "ready to cook" solution, you have to make some efforts to get some results !
If you read it thoroughly you'll find the answer to your last question in replies #12 & 20 from our amigo Julio...
BRs, Bernie
yes i know, thanks. I want to add the rain sensor becouse i add the elettrocromic mirror but i dont find the body scheme and i dont know how do.. i'll try to find a solution ;)
No, i dont have. Do you have the wiring pre-installed for copying the wiring?
Here's how it connects ...
BRs, Bernie
Yes i know the connect but i dont have the body scheme for find connector and connector a. The electrocromic mirror can be connected to the ceiling lights or mush be connected to the body? Thanks
Here is the drawing of courtesy lights where you can see the connector A on the BCM...
wow thank very much!!!! now i downloaded elear, i hope to find how connect the electrocromic mirror, becouse the rain sensor is connected to the mirror and after there's a unique connector and if i can connect like orignal its better, otherwise i must do 2 different connection
I couldn't find anything about "electrocromic" mirror in eLearn :-( so if you do, please share...
BTW, this stuff is supposed to be an "anti-dazzle" mirror...
BRs, Bernie
yes anti dazzle mirror, there are something on elearn?
no, there's on grande punto/alfa mito and 500 and its the same item
They are also in some fiat tipos my 17 plate lounge has one
New model, I though about the tipo after I posted, but still not 100% convinced they ever fitted them to the grande, bearing in mind they stopped making the grande in 2010.
It took till 2015 before they even offered cruise control on the 500.
Anti-dazzle (elettrocromatic) mirror arrived, there's the cable for rain sensor! now the problem is find something for connect the mirror to the body.. i search on the elearn but nothing! Maybe ive an older version becouse there'snt the 1.4 tjet....if ive some good news i share with you!
