General radio model help?
johnnyGentleman
hello i need help to find which radio is this. And the manuals also. Is there someone who can help me? Thanks
thanks a lot for your answer! this one doesn't have the colored screen and its not working so its been really hard for me to find the right model. Probably I have disassemble it to check :(
The inner section with screen is not standard on the Stilo.
The outsides are. Look like somebody had a broken screen and tried to replace it with a display from whatever.
No wonder it does not work.
As mentioned above, it's a basic Connect Nav unit. The screen doesn't show full mapping, just arrows that point which way to turn. I believe it uses the same map disc as the Connect Nav+
As far as I know, there is no online instruction manual for it, but it's operation is described in the early paper Connect Nav / Connect Nav+ manual that was supplied with the car. Apart from mapping, all other functions will be the same as the CN+ which are described in the downloadable manual in Eklipz3k's link above.
