- Joined
- Jun 19, 2018
- Messages
- 94
- Points
- 70
Hi guys. I need a drain tap for my 2012 1.4 Punto radiator. The original was white (ish) plastic. An alternative that fits is OK.
Thanks in advance.
Thanks in advance.
Thanks in advance.
This is a screenshot of one on ebay. 13mm wrench but 8mm screw too small diameter too small. I think it may be 10mm thread, but I'm afraid of damaging it and I only have a 10mm which is 90mm long. [emoji853]Hi
Probably a standard metric thread..
So you could use a screw: bolt
Did you look at a direct replacement ?
Shop4parts can probably help there..
Or search yourself
https://www.fiatdalys.lt/en/catalog/diagrams/104/6U/0/0/CC1.4/CMBBZ/GDX/cooling-system
What's wrong with using that one after fitting a new rubber seal washer?Sorted now. This is the offending article [emoji16]View attachment 215728
Good news..!!
Thats a pretty coarse thread..![]()
