General quick rebuild !
premrajeev
Kerala,India
Well here are some pix of my quick rebuild.
Scheduled to complete in 15 days, work just started yesterday.
Processes planned :
1.Cylinder 3 oil seal change, head gasket change
2.Valve gap setting and correct timing.
3.Waterpump replacement (done)
4.chrome finishing of rocker cover
5.new spark plugs, oil and air filters
6.carburettor servicing
7.fuel tank and fuel line flushing & maintenance
8.Clutch liquid - change and line servicing
9.all brake pads & shoes : renew and bleed,adjust.
10.clutch/accelerator/brake pedal play adj.
11.Wheel balancing/alignment
12.Speedo - removal and refitting new one
13.bonnet opener cable change
14.new headlight units and clear indicator/side repeators
14.rear light cluster - renewal
15.new number plates
16.seats reconditioning and new foam/clothing
17.new sound system - all ready to fit:)
18.Front windshield-removal and replacing with new
19.replacing std steel rims with alloys
20.full respray with slight dark shade blue
21.welding, restproofing , waterproofing.
22.fitting of front fogs
23.fitting of auto security system w/central locking
24.electric front windows.
25.Possibily meshed grill
26.colour coded bumpers
27.front new bumper
28.seat belt - passenger side (u know why:bang: )
29.new side mirrors L/H &R/H
30.Stainless steel tailpipe for exhaust.
31.flushing and refilling the cooling system
32.refilling gas into the airconditioning system.
any item not listed will be included at a later stage,
here are some pix to start with.
Wow, well done fella.
When you've done each thing, give us a little pic (before and after), the number, and what you've done... good potential, this car has, but I'd say the thing that lets it down most is the dents... shows her age.
Get em popped, filler em, and restore...!
removed the dash board today :
Also, delocked the boot as u can see below :
Also done some quick welding , amazed to see very little rust, largest being on the right rear doors !
finished all dents.
all set for a respray soon !
goota get some sand paper for next few days !
looks like your getting stuck in there, are you doing the work yourself, dont forget its all in the preparation, take your time all you'l regret it later, dont throw a shine over it until happy,
err
to an extent, buddy.
My welding skills are not up to date, and sheet metal is being worked by someone else.
I will try the paint, though.
Will open the engine head tomorrow.
More to come !!
Good luck with the project Premrajeev (y) Looks like you are doing a lot of work in a short space of time, and as antsuno says take your time in the preparation stage.
"Preparation is everything" is a saying used a lot in the restoration industry. Painting a whole car takes literally less than an hour (depending on the number of coats), but is only as good as the quality of preparation beneath it. Take your time and make your Uno shine :D
Looking forward to seeing some results soon :slayer:
Wow, ur right on track aint ya...
I agree with him above, 95% of the finished item is all in the prep work, fillering and sanding down smooth and priming the car.
if all these are done correct and the top coat is applied by some one who is a good sprayer, then this could be one of the cleanest 5 door uno's around..
Keep up the good work bud.....:)
well so u r still on fiatforum aint ya ...:cool:
Well I'm gonna spray it myself so dont think it would look great..
Then..who knows - a miracle can happen any time:D
Will post latest pix tomorrow.
Yes mate im still here, i sold the uno and made a fat amount of proffit, but that dont stop me lovin the old fiats...
Im gonna stick around as i might get another one soon but this time im gonna re shell a 45s with turbo running gear and engine, keep the outside stock, then blow people away in a stock looking 45s lol.......
just need a donar car now :devil:
whooha !
here is the progress :
Sanded the old paint, now putting first coat of primer ..
Well I missed the seatbelt spring for now :p
Will get a new one..It's not binned though, may try it on another crazy day:D
Now, tomorrow may be the first coat of paint, after one or more primer coats...
I need a new windshield, Hell expensive !:eek:
Well need a new sub as the current one is fooked :(
Any Suggestions - Limited resources -12" Sony / Pioneer /Alpine / Kenwood
not after locals any way.
Have to remove the rear bumper tommorrow..will be needing loads of WD40
or a gas cutter if it doent help..
Will post more tomorrow .
Will have to order parts for the engine and steering rack (oil seals/piston rings and bushes)
Lot's of work to do :rolleyes:
mate ,you should have masked off the lights and anyother buts that you dont want primered ,ie bumpers!
looks good though!
hello both of u there !
The lights are of course be removed as they'll be replaced by new ones!
and the bumpers are going to be colour coded....
hoping to finalize the painting process by this sunday !!
Thanks for yr interest.
here are the latest pix..
looks good though!
If you look at the pic mate its been painted and where they have wet and dried it back you can see all the water run marks on the bumper.
Gotta hand it to him thou, doing all that in a out side lean to cover...
looks like its doing ok bud, cracking on wiv it well i see..
drag,,
man....where are u these days !!
Waiting for yr respone..
I have to start the refit in a week or so:)
white dials , turbo cluster - or even an sx pod :(
help ...help...:cry:
phew !
after lot of sweating ,finished the painting work yesterday eve.
Will post some pic today after getting her serviced.
Spent around 500 pounds ...
Engine & suspension works still pending, and has been re-scheduled....:D
Well, for all those who were curious -- I have binned my seat belt springs and the other bits too :p
better loosing a spiring to an eye..;)
Hah, hope you got the pictures of the new dials I did for you man.
Said you didn't need a turbo cluster, so that's cool.
I'd think about getting a turbo centre console though. They make the interior look more substancial.
Good going on the Uno, looking good.
