Hi Qubonauts (what is the right word?)
I hope to join the clan and will look at a 2010 1.3 MJ 16v later today.
It has a full service history with the familar Qubo woes.
I have some questions:
DPF or no DPF?
Has anyone got a picture (or link) of an early Qubo DPF, so I know what I hoping not to see?
I've looked through the threads and asked a dealer if they can tell me if this car does or does not have a DPF. They assumed it would have one, but couldn't see from their records that it did. So they suggested a visual inspection to confirm it.
The dealer said that the Euro 4 DPF is installed down the back of the engine. It is a box at the beginning of the exhaust pipe and has some other tubes going into it to sense the flow rate through the DPF so it knows when it is clean or dirty. Apparently later DPFs (Euro 5 versions?) were squeezed in up front by the radiator.
Clues I have already:
Front suspension
Anything else to check other than steering clunk lock to lock, or springs going bong when held and someone else does the lock to lock thing?
Service history clues:
Front top mount bearings have been replaced twice. From what I can see the dealer replaced just the bearings and fixings, but not the pads.
It's had one new LHF shock (due to a leak) and one OSF spring. I presume that these failures were preamature due to the bearings failing. In its early life the tyre wear was even, then the OSF started to wear on the inner edge.
If we buy it: I'll need to protect the top mounts from further weather damage; and keep an eye on OSF inner tyre wear and get it retracked if required.
Service history
Other than disks/pads and the suspension replacements all seems OK.
Next service is 80K; The book says replace: aux-belt; all filters and fluids.
Timing chain replaced later at 100K?
Is there anything else Qubo specific to look out for?
Thanks folks. C.T.
DPF or no DPF?
- The instrument panel has no DPF light on the dash
- The car is rated as Euro 4 emissions
- EPER didn't reveal any clues that it had one, but I a newbie so I might have been looking in the wrong place for the wrong thing.
- There is NO forced DPF regeneration option.
- EuroCarParts does not show a DPF as a part for the registration plate.
- Read other threads https://www.fiatforum.com/qubo/457864-dpf-identification.html
Front suspension
Service history
Thanks folks. C.T.
