Wonder if anyone can give me some suggestions on a problem with my Wife's 2009 Panda 1.3 multijet. When idling there is a slight misfire which perhaps I could describe like this;- "mmmmmmmmbrrbrrmmmmmmmmmbrbrmmmmm" but when the engine is cold or warming up its not there and also if you turn the headlights or rear window demister on the misfire dissapears but if you increase the engine revs a little with the pedal the misfire increases ie "mmbrrbrrmmbrrbrrmmbrrmm", Hope that makes sense. It runs sweet as a nut and starts no bother and is doing 65+ mpg, its just that annoying murmer at idle thats got me baffled. It doesnt throw up any fault codes and I've checked all the fuel lines for leaks in case it was sucking in air. The EGR was causing issues as it was stuck open but that has been closed and disconnected and didnt put on the eml light but hoping its not that as its a pain to change and I would imagine the misfire would be there all the time if it was that but I stand to be corrected.
Thanks in advance
Thanks in advance
