Wacka
Hi guys, have a problem that's just started today. The city button light is flickering on and off pretty much constantly, at all speeds, so steering is going normal/light/normal all the time. Any ideas to the cause?
waiting on local fiat garage to get back to me, hopefully will be cheap
False if you really want to svae money then you can download MultiECUScan on your laptop and buy the rigth diagnostic cables of ebay or amazon for cheap and run the diagnostic yourself, this way you know whats up with teh car and get the problem sorted without being shafted by garages![]()
hi
multiscan wont help here
at best random codes will appear
im surprised indy cant help
its something silly im sure
i still think its something silly like a loose rear speedo plug rather than major bsi issues
Ok, update to the old problem.
Since February when the codes were cleared everything has been fine, until today.
Car was turning over but wouldn't start and the immobiliser light stayed on. Tried spare key with no luck, so called out the AA.
After a good hour of checking everything he could think of, earthing points, fuses, that the key was 'transmitting'? He found the cause, a loose connector, just below the indicator stalk when the steering column cover is removed. Connector securely back in place and hey presto, it's alive!
Pee'd off with myself for not getting it properly sorted the first time round, but hopefully this might help someone else who has a similar problem!
