crankshaft
- Joined
- Feb 13, 2017
- Messages
- 136
- Points
- 87
Punto Mk2a Engine Surging
Hey,
My Punto 1.2 16v from 2002, has 2 problems related to the engine, and I am not sure if they are related, or not.
The CO emissions are a bit on the high side when the engine is idle. The car idles fine, there is no rough idling.
If you press the gas pedal, the CO emissions go up, and are slow to come down, but something else happens, you can't keep the car at a fixed RPM value, like 2000 RPM, it's almost impossible to do that.
Without moving the gas pedal, the RPMs start going up to the 4000's and then start coming back down, and repeating that.
Sometimes it will behave fine, and will be steady at the 2000RPMs, and it's easy to make it stay at a fixed RPM value, has you would expect.
Anyone has any ideas what could be going wrong with my car?
I have no idea when this started, because the car idles fine, and it drives fine.
When actually driving, the RPMs stay steady, and I don't notice a thing, there's no RPM hunting or loss of power or hesitation.
The fuel consumption information shows about 20km/l which is good for this car. I don't notice it consuming too much fuel, but I would have to test that out better.
The reason I noticed this was because they warned me about it in the annual inspection, MOT in the UK.
Hey,
