Hi there
Im in the middle of getting a new engine installed in my mk2 punto (x reg - 2000). But before i needing this done my head gasket went in the old engine. i realised that when i was driving my car or waiting at traffic lights the fan would never cut in when it was suppose to.
I know that the fan was definitely working cause when i put the positive(+) and negative(-) wires up to my battery the fan goes like mad. It works with a perfect breeze. However when wired to its original wires it does not seem to turn on no matter how long the car is sitting idol and heating up.
I was told of these possible problems:-
1. I was told that it may be a relay from the 'Fuse Box' ???
2. It may be the thermostat is not functioning properly - hence not
letting any water in to cool the engine???
3. It could be a temperature sensor that is not functioning. If this is not working it can stop the fan from kicking in when it should due to the sensor not being able to give a reading ????
If you have any ideas as of what it could be, please give me your thoughts on the issue. PLEASE HELP ?????????
