Hello all.
I last left this post with the ecu going off for testing at a specialist, they ran 2 test cycles on it both for 40 mins and it passed!...
So after a lot of trial and error I found the wiring loom had some insulation above the inlet manifold and the crank sensor shielded ground was hanging on by about 5 strands of wire when I really dug deep into the loom.
After repairing and refitting the loom the car tries to start but doesnt "catch" after maybe 5 or 6 attempts it ends up flooding the plugs. All 4 injectors are pulsing with a noid light, all 4 plugs have good spark but it seems to be overfuelling.
The mad thing is when the ecu came back from the specialist I set up an oscilliscope ( bought of amazon ) to read the crankshaft sensor signal, I got a nice clean square wave and the car tried to start!!
.. After a few tries it was successful and I let it run for about 45 mins, it would rev and boost up ok, key off and key on started on the button. Went off for half an hour came back and it wouldn't start again...
Today I even checked the timing in the rain 🌧 to make sure the crank pulley hadn't slipped on a worn woodruff key but its spot on..
Any ideas would be much appreciated! Thanks
