Kevin Hammond
- Joined
- May 25, 2010
- Messages
- 50
- Points
- 18
The gearbox on my Punto Active sport I bought recenty has a couple of issues. It makes a horrible grinding sound when running in 1st gear. A not so good sound in 2nd, but OK in other gears. It engages in each gear OK. I recently put a new clutch in , but already this has started slipping - I wonder if I have oil leaking onto it from somewhere - how likely is this on this model?
ALso, since I replaced the clutch, the position of 5th gear has moved (both at the gearstick and also at the selector itself (I wonder if I have damaged the internal selector as we accidentally used the selector to manhandle the gearbox back into the car (it was a tricky manoeuvre). Sorry this is a complex problem - so any ideas would be welcome.
