Technical punto alloys
baldy1967
dartford
does anyknow if 15inch alloys from 2006 grande punto will fit 2005 punto mk2b
thanks in advance
they would with wobbly bolts, as the pcd is diffrent on grandes, you may need spacers, do you know the offset ?
You need to know more before posting mate, as you'll end up costing someone money.
OP - the bore is different (56.6mm), they will need to be re-bored to 58.1mm by a machine shop, PCD/wobbly bolts will also be needed as the PCD is 100 and needs to be 98. Spacers shouldn't be required unless lowered.
