Technical  Propshaft replacement on Panda Cross
Enigmatik33
Hi Folks,
Having to replace the Propshaft on my gf's car this afternoon due to the failed mount for the bearing. Did strip it off with my brother but disassembly was a night mare so ordered a replacement. However, I can't find the torque settings for the:
bear mount
transfer box bolts
rear diff bolts
bear cover
anywhere, can anyone on here help?
Ross
i have just replaced mine (£220), from what i can work out from the elearn cd, after a bit of converting units, the 12 allen bolts should be 40Nm, re-covering in red loctite. the 2 central bolts 50Nm re-covering in blue loctite, the guard i haven't found a figure for, or replaced so far, sheared two studs when removing :bang:
please use this as only a guide :)
