- Joined
- Oct 20, 2007
- Messages
- 4,940
- Points
- 744
where did you get the cage? do they do one for a sei?
Did you already pick a nice color for the cage? or respray it red again?
Keep it going!
Well got a nice surprise yesterday, a member on here (cinq noz) lives not to far from me and found he was giving a Sparco Strut brace away for free so now sitting by me I have a rather rusty, but solid strut brace. Alls good.
Also here's a picture of what i was trying to explain the other day.
Sion
I take it that you know how the cinq selector works/looks (pivot at bottom, cables attached to stick). The punto selector works (well how I think it works, I'm pretty sure about it) more like a conventional selector, with the pivot in the middle, and the cables attached below.
Now when using the standard stuff lifted up, you have to bring the cables inside and that big box thing (can be changed if you want obviously). With the punto selector, you could keep the cables under the car and bring the pivot point up higher so you can make a short shifter by shortening the gear box end.
Any clearer? lol
Sion
Also, looking at RepoBoy's thread where he has converted a P75 engine into a 16v has got me wandering. You can fit the P75 head onto the 1108, and hes successfully attached the 16v head to the P75 bottom end, then by my understanding this would mean a 16v head could be fitted onto the 1108 block. I'll try and get head gaskets or something to compare if I can, but. It's got me thinking about future engine mods...
Sion
...Also, looking at RepoBoy's thread where he has converted a P75 engine into a 16v has got me wandering. You can fit the P75 head onto the 1108, and hes successfully attached the 16v head to the P75 bottom end, then by my understanding this would mean a 16v head could be fitted onto the 1108 block. I'll try and get head gaskets or something to compare if I can, but. It's got me thinking about future engine mods..
To then by my understanding this would mean a 16v head could be fitted onto the 1108 block. I'll try and get head gaskets or something to compare if I can, but. It's got me thinking about future engine mods...
Sion
Also mean the 1108 head will go onto the 1.4 block ?
Ming
Did you also take into account the possible clearance issues with the intake manifold?
I've mounted a p75-head with p75-intake onto a 1108 base, however I had to make some adjustments to the firewall to cope with this problem (Arc did the same thing on a cinq with the same problem ), and it was not easy to get the intake in either
I don't know anything about the size of the 16V intake, but it was just a quick flashback to what I had to deal with
Keep it up
I think the cam belt would be the problem with the shorter block.
SPD
