Contrary to no updates on here I have been doing a bit of work on the car. Again not as much as I liked as I'm back in uni and the car still isn't finished, but there has been progress.
Decided that I am going to weld the rear feet onto the car, came to my senses.
Have all the bits to fit the seats, and fitted one seat (sort of).
Been very kindly given a set of 3 point harnesses (I'll switch them for some 4 point 3" ones once I've finished.
Bias Valve fitted between seats.
Front half of braking system finished.
Washer bottle removed (going to fit one where the battery used to be).
Few other little things.
Now the even bigger list, things to be done.
Get it to start (something still isn't letting it start so gona renew all earth points, new bigger battery and check everything I can think of)
Wire cut-off
Exhaust system (all new rubbers, back box and few extra hangers)
New metal cable ties on inner CV rubbers
Fit new front struts
Finish rear brake lines
Fit new washer bottle
Fit and repaint strut brace
Vent and block charcoal canister pipes
Fit stud conversion properly
Spacers for front and rear
Finish seat mounts
Captive nuts for harnesses and boot straps
Finish bolting all bits of the cage and weld rear plates
New rear hubs
New disks and pads
And miscellaneous rally parts (cage padding, foot rest, clock, jack plug and cigarette lighter - moved to where speaker used to be, interior light and helicopter tape on cage)
Also a general service and adjustments.
Hopefully once that's done it can go for an MOT.
Going to be collecting all the parts over time until Easter-ish then one massive push over Easter should see it finished and ready for an event in June. Hopes a nice thing.
Sion
