Punto (Mk2/2b) Problems on my fiat noobie.
Seeking tips and advice
  • Restoration
    Votes: 0 0.0%
  • Stop Engaine failer
    Votes: 0 0.0%
  • Keep the engaine healthy
    Votes: 0 0.0%
  • What are common problems
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Gizmogrant
Hello,
My name is Grant. I have been driving for a year now, My first and only owned car is a 02 Punto go edition , it had 56 on the clock when i had it , it now has 73 . I also do change regally every 6k. :D
I plan to do it up and make her work properly so far i'v had a new gasket, new engine pump,new fuel pump,new starter motor, I had the leeds changed on her late last year, new exhaust , new hand brake cables on each side,as well as spark plugs. Im changing the plugs this week. I take it to a garage i well know.
so labour is pretty cheep just need to pay for the parts.And also i have put a 2nd wiper unit in because the last one kept latching off
I have no experience on how to work on car engines. :worship:
so can anyone tell me what other things i can do to try and make sure that there is no failure or brake downs
anyway I was driving my car this morning the power steering cut out ?? i turned the engine on and off it worked agin ???:cry: :confused: , I also notised so rust growing ONLY on the bottom side of the driver's door :bang:
Another frustrating thing is a yellow light bulb comes on when ever i brake ? the brake lights do work !!! , so are the brakes wearing down ?? but i feel that they work fine ?:bang:
Anyone out there who can help me by giving me some tips and points in what way to go on trying to keep my fiat for a long time, as i want to do her up
and what are the common faults on these
Regards
Grant .
Hello,
Regards
Grant .
Hi Grant, and welcome,
I've goa similar 1.2 2002 punto , had a couple now,
Faults = Head gasket,Wier assembly, power steering, water pump + LOSING KEYS,
you've covered MOST of that already...,
Power Steering uses a LOT of battery / electrical power,
MY tip = when you start up , let ALL of the test lights go out , then start the car that way everything is all set for driving , if the steering STILL messes about consider a battery / charging system check.
MY 1.2 will ALWAYS knock-out the steering if I turn the key instantly without it doing it's checks , works 100% otherwise,
Headgaskets are an issue - but you've done that,
re your brake light.. check that its not a low brake fluid level ,
other than that - look after it and enjoy it,
Charlie
Waterpumps are only an issue if they aren't changed at the service schedule tho
Never ONCE had a problem with water pumps
Anyway
Coil Packs - Fail causing a bad misfire
ECU failure - Fails to tell coil pack to spark
E-Power steering - Low/weak batterys make light come on, torque sensor fails = new coloumn
Wiper Linkages - water logged due to no scuttle pannel drain
Ball joints drop off - fixed with a washer or £3 ebay clip
The Common but not as common
Clutch slipping after new clutch = Input seal blown - rebuild + new clutch
Drums seize/dont self adjust = Lack of maintaince
Airbag Interferance detected = Wiring loom from fiat + FES to reset
Flat battery = After market stereo not wired correctly
Flat battery = Alternator regulator remains active after switch off
Maincat holes/rusting off - Lack of maintance, catch it early or have it welded
Rear floor pan rusting / holes - Lack of maintance, welded up and protected
Ziggy
