Technical  Problem with Sat Nav/Heater panels
Rafair7643
Hi there,
Been having problems with wiring, thanks to a mouse using the car as a home. :bang:
This lead to the roof opening and jamming there. Managed to manually wind the roof shut and to make sure of no repetition disconected the wiring from behind the switch in the roof panel.
When I restarted the car, the Sat Nav and Heater control panels failed to illuminate. Not so bothered about the former, but the latter is essential. Any ideas on tracking possible sources would be gratefully received.
Is there anything within the central roof panel which could in any way effect the running of these two items?
It's likely a case is chasing the wiring for them and finding where the fault is
Id personally start from the fusebox seeing if you have power there and then work your way either to the battery or towards the panel depending on if you have power or not
