Technical  Problem with remote control locking
demokedes
Hello,
I bought used Fiat Idea 1.9 JTD, year 2005. I am using car for one month now, and I am quite satisfied with it. But I have one mistake, that I can not fix. Seller warned me, about remote locking, that is not working. He said that probably I will just have to change battery.
I changed battery, but problem persist. When I press unlock button on key fob, red light blinks on key fob, but car does not react.
I don't have security code.
Is there anything else that I can do, to get remote locking working?
Can someone please give some guidance on how to reprogramm the code? What cables do you use? I have two cables and I have been messing around with those but I don't know how to get this thing to work. I have the immoblizer code and also have those coloured adapters.
and these four adapters
any help will be much appreciated.
Hi, and welcome,
as you'll see it's pretty quiet in here..,
do you have FES / MES , or examiner software,
the MES site should list the gear needed to reset this,
I would ask in the TECH section,
or 1st= do a SEARCH - advanced,
remembering that the Idea is a Punto2B underneath.. so most relevant posts should be in that section..,
good luck,
Charlie
