Yorky
I thought i'd cured the intermittent problem with the 1.6S Brio but it's back. To re-cap, it runs fine but occasionally at 70 - 75mph the power just fades. It will not pull and there is nothing happening when you put ya foot down. Stopping for a few minutes and waiting it will re-start and run perfectly until the next time. It could be many miles or days before it happens again. Having changed the plugs, in line fuel filter, rotor arm, distributor cap, cleaned the carb jets and drilled holes in the fuel filler cap i was running out of ideas. As you do, i was gazing in to space with the telly on when i had an idea. My old Ducati bike has been suffering from exactly the same problem. It was diagnosed as the Marelli Digiplex ignition unit. Apparently they are known for being unreliable and what happens is with age the soldering contacts inside the unit become brittle and start to disintegrate. I checked the car and found that this was also a Marelli Digiplex unit. Having sourced another unit from a breakers for £20 i've changed it over and so far everything is OK. I'll keep you posted. P.S. The unit for the bike is like rocking horse poo and cost over £400 new so if anyone knows of a second hand one please let me know. It's for a Ducati Paso 906.![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
