Pre- heating
This has been discussed a few times.
You don't need them unless you're winter-driving in northern Siberia, or somewhere colder!
Even then it'd probably start with a couple of seconds cranking.
Remember, Diesels are 'compression ignition' Engines, the heat created by the high compression ratio raises the temperature of the air/fuel enough to ignite it.
Mine has been flashing for months now after start-up, still starts immediately no matter how cold it is or however long it's been standing for.
I never wait for the self-check to do it's thing, just go straight to start as soon as the key's in the barrel, i.e. giving the plugs no time to heat up anyway.
Before my last Multi finally died, I was planning to disconnect them just to prove the point, might still do it on the current one . . .
