Technical  Pre Cat Temp Sensor replacement
markbridge80
Wiltshire
Hi all, just replaced the Pre Cat Temp sensor on my twin EGR 2016 2.3 Ducato, does this need to be relearned by the ECU using Multiecuscan? I couldn’t see anything in the menu for it so just double checking I am not missing something.
Many thanks
There's no such option in the MES, so programming probably isn't necessary. The DPF also has a temperature sensor before and after the DPF. It's worth checking if the readings are similar when driving calmly. Assuming the filter does not regenerate
Page 53 of my owner handbook:
"TAILGATE CLOSURE
To close, lower the tailgate by pressing near the lock until you hear it click.
In the inner part of the tailgate a strap B fig. 54
makes it easier to hold and close the tailgate."
Hi Jock, did you mean to post your response in another thread?
