Hi, thanks for response. The MH is on a storage pitch with a portable 20watt solar panel, nearly, keeping it charged. It had 11.8 volts when I went down yesterday (it started ok) and 3 weeks ago it was 12.4 volts? Will check the fluid in next few days. Thanks
11.8 volts is low for a 12v battery, around 25% state of charge. You shouldn't really allow it to drop below 12.0 volts as an absolute minimum, preferably 12.2 which is about 50%. Anything lower can cause irreversible damage especially if left for some time. A fully charged battery should be at around 12.6 volts or slightly higher.
A 20w solar panel is very unlikely to keep the starter battery charged over the winter months. You won't be getting anything near full capacity out of it, and what you do get will only be for a few hours each day with low winter sun. There are ECUs and other components on modern vehicles that still consume power even when the vehicle is not being used, so you probably need to give it a boost charge from a mains charger at least once a month.
Hi, Rs3100 thanks for info, I collected my MH tonight and it’s on charge at my address and the power steering warning light is not on now so I will fully charge the vehicle battery and then do so every 3-4 weeks.
Hello, your sage advice to check that the power-steering fluid's at the correct level raises the question, for me, as to how to determine the maximum level (given that one must not 'overfill'); i.e., I cannot determine whether or not my fluid is at the correct level because there's no 'maximum' indicator on the reservoir. I'd appreciate the benefit of your knowledge, please.Start by looking under the bonnet
Is the fluid and the correct level?
Does it look like the belt is correctly attached to the pump?
After my problems with the drained battery it will not take a charge now and is still reading 11.8 after a day and a half. If I have a new battery fitted will any of the electrics on the MH be upset when disconnected and have to be reset?
I asked this question yesterday but since it's not shown up I expect I didn't complete the process.Power steering My question was to the effect that I cannot determine the maximum level for power-steering fluid, there being no mark on my reservoir. Are you able to advise me, please, on how to kn My question was to the effect that I cannot determine the maximum level for power-steering fluid, there being no mark on my reservoir. Are you able to advise me,ow how full the reservoir needs be - when is the fluid at maximum level, and when not?Start by looking under the bonnet
Refreshing the site shows my follow-up question was superfluous. Thank you, Crossing keeper, for putting me in the picture.PGH, your other posts indicate you own a 2009 2.3 X250; if so the power steering fluid level is not marked on the reservoir but on the dipstick attached to the filler cap.
