Technical  Power steering pump serviceable?
Bauk
Hi!
My pump is leaking ATF, wondering therefore if the pump is serviceable in anyway?
Thx!
(Punto Cab ELX, 1.2 16V)
I would have thought a local hydraulic company could do this as im sure it would only be a seal that would need replacing.
Ill have a look at an old one that i have lying around and see if i can get it apart.
Went ahead myself as well. It's possible to remove the backing plate ring, but haven't found a way yet to remove the backing plate itself. It's not moving by after the ring is removed, so I am guessing it's has been pushed in.
Anyone a clever idea how to remove it undamaged?
Why not? Drill a hole in the housing and push out the blind circlip! Dismantle , new seals and bearing! Sinple bench job.
